Hi !
Recently I have upgraded from 300mb fttp to 900mb fttp package. In the past I had no issues reaching 300mb on R2 however 900mb seams to be a problem.
At the moment I get around 530mb on R2 and ISP Smarthub2 is able to get 950mb+ either on speedtest, BT line test or even on XBOX.
My R2 is connected to GPON terminal via PPPoE. I have looked at the guides and disabled port scans, IPv6, QoS etc but without any change to the speed.  Is R2 even able to get speed around 900mb ?
Have you put the R2 in the DMZ on the BT Hub and are ALL devices connected to the R2? It definitely is capable of getting up to those speeds - what speedtests are you doing?
