Ryanw Posted April 13, 2023 Author Posted April 13, 2023 that was my issue. thank you. Netduma Fraser 1
Ryanw Posted April 18, 2023 Author Posted April 18, 2023 So, now my game bandwidth is under 1k, it sits about 800. when it usually sits at 4,000. why is this? and i already unplugged the router and waited and turned it back on and it did nothing.
Administrators Netduma Fraser Posted April 20, 2023 Administrators Posted April 20, 2023 On 4/19/2023 at 12:35 AM, Ryanw said: So, now my game bandwidth is under 1k, it sits about 800. when it usually sits at 4,000. why is this? and i already unplugged the router and waited and turned it back on and it did nothing. Hard to say, have you changed any QoS settings prior to that happening? 800 is still plenty for gaming, it's unlikely having the higher bandwidth would make a difference in game.
Ryanw Posted April 20, 2023 Author Posted April 20, 2023 no i havent made any changes in the QoS. they have been the same for months. i used to get 4,000. so to drop to 800 is weird. when i plug my PS5 into the modem i get the higher bandwidth again though. so it has to do with the router not providing that speed. I was just curious why it would all of a sudden be so low.
Administrators Netduma Fraser Posted April 21, 2023 Administrators Posted April 21, 2023 15 hours ago, Ryanw said: no i havent made any changes in the QoS. they have been the same for months. i used to get 4,000. so to drop to 800 is weird. when i plug my PS5 into the modem i get the higher bandwidth again though. so it has to do with the router not providing that speed. I was just curious why it would all of a sudden be so low. If you disable the Geo-Filter does the bandwidth report the normal speeds?
