glaglaman Posted July 20, 2015 Author Posted July 20, 2015 You could delete the unnamed devices that don't have an IP and then they may get redetected and may give you a better idea as to what they are. Glad to hear it seems to be working now though Wow seriously ? I can delete those devices ? how do I do that on my netduma ? Thanks for the hint.
PharmDawgg Posted July 20, 2015 Posted July 20, 2015 Go here. This may help. http://wiki.netduma.com/doku.php?id=device_manager_settings&s[]=delete&s[]=devices
glaglaman Posted July 20, 2015 Author Posted July 20, 2015 Go here. This may help. http://wiki.netduma.com/doku.php?id=device_manager_settings&s[]=delete&s[]=devices Thanks I've read it carefully. What if a delete a device (not blocking ... just deleting) and finally see that it was my own laptop ou other device. Can it get back to where it was ? (can I re-assign it to the netduma ?)
Administrators Netduma Fraser Posted July 20, 2015 Administrators Posted July 20, 2015 You can only delete it if its not currently being used so if you did manage to delete your laptop or other device, when you connected back to the R1 via wire or wifi the R1 would detect it again and be able to use the internet
PharmDawgg Posted July 20, 2015 Posted July 20, 2015 If I'm understanding you correctly yes. Once you try to access the netduma network with the device it will place it in the list of devices on the netduma and probably give it a nameless title but you can rename it yourself.
glaglaman Posted July 20, 2015 Author Posted July 20, 2015 Ok thank you very much I'll try that to see what's happening.
