The Honest Tiger Posted September 26, 2022 Posted September 26, 2022 Okay, so even though the guide indicates I should have my PS5 filtered to get the best possible server for my connection, I'm finding that it only helps with my connection to other people. I had my PS5 filtered and strict mode off and got into servers at 80 ping but when I reversed the roles, I was getting connected to my closest server.
Administrators Netduma Fraser Posted September 27, 2022 Administrators Posted September 27, 2022 You need strict mode enabled otherwise it will allow servers outside your radius. Strict Mode is a feature we introduced specifically for Destiny and I would highly recommend you only disable it for that game, that is why it is enabled by default. Enable it again and it will work as expected.
The Honest Tiger Posted September 27, 2022 Author Posted September 27, 2022 12 hours ago, Netduma Fraser said: You need strict mode enabled otherwise it will allow servers outside your radius. Strict Mode is a feature we introduced specifically for Destiny and I would highly recommend you only disable it for that game, that is why it is enabled by default. Enable it again and it will work as expected. I know how it works, just on initial setup it states that the filtering is what blocks servers outside your connection, might need changing to other players and not servers.
Administrators Netduma Fraser Posted September 28, 2022 Administrators Posted September 28, 2022 It does filter servers, that is the main purpose as most games are server based now. I’ll talk with the team to have the description of strict mode be made clearer, thanks for letting us know your experience.
The Honest Tiger Posted September 28, 2022 Author Posted September 28, 2022 8 hours ago, Netduma Fraser said: It does filter servers, that is the main purpose as most games are server based now. I’ll talk with the team to have the description of strict mode be made clearer, thanks for letting us know your experience. It doesn't though, I have my filter off but strict mode on and servers outside my radius are being blocked.
Administrators Netduma Fraser Posted September 28, 2022 Administrators Posted September 28, 2022 I'm not sure I follow, if it's blocking servers outside your radius then it's working as expected, unless you're saying it's doing that with Filtering Mode disabled?
The Honest Tiger Posted September 29, 2022 Author Posted September 29, 2022 Yeah, I would disable my filter and it will block servers and players outside my radius even if I haven't blocked them.
Administrators Netduma Fraser Posted September 29, 2022 Administrators Posted September 29, 2022 Could you provide a screenshot of the Geo-Filter page showing when this happens please?
