LGC Posted July 21, 2022 Posted July 21, 2022 Hello all, I recently upgraded my speeds to 1200mbps and doing tests, I can't get my XR1000 to reach near this speed. Had reached Xfinity and everything seems to be ok. When testing my PC wired to the Xfinity router/gateway I'm getting speeds around 1280~1310mbps. When I wire my pc to the Xr1000 I can't get more than 912mbps. My Xfinity router is in Bridge mode, connected to my Xr1000 using the cat cable provided in the box and from the Xr1000 I'm using CAT6 cable. I don't thing my problem are cables since when connected to the Xfinity router I'm getting more than the plan offers, so, as Xfinity said, my services are at 116%. On my XR1000 I have QoS disable and since I have updated speeds and gateway, I have performed a hard reset 2x. I'm not sure if I'm missing something or not but any help is welcome.
jame0174 Posted July 21, 2022 Posted July 21, 2022 i also had this problem .So i switched to the r2 which was better until today
Netduma Liam Posted July 21, 2022 Posted July 21, 2022 Hey! I've responded to you on the NETGEAR forum
