Mehmet Posted April 11, 2022 Posted April 11, 2022 Why doesnt Geo Filter work in other games like in warzone ? For example Apex for example destiny 2 , Overwatch or Fortnite ? Or is it just a router just produced for warzone? Orr i do something wrong on geo filter.
Administrators Netduma Fraser Posted April 11, 2022 Administrators Posted April 11, 2022 What exactly happens when you're trying to filter these games? Regarding Fortnite the way their matchmaking works they only try to connect you to a server when you load in so that's the only point we can block. Will likely be quicker for you to disable, see where the server is then quit and re-search.
Mehmet Posted April 11, 2022 Author Posted April 11, 2022 I ve problems in apex. i think you cant optimize apex searching like warzone. When i search in apex if the game find match out of geo filter it kicks me out of game to the main screen. Then i must login again to play. Can you fix this problem ?
Administrators Netduma Fraser Posted April 11, 2022 Administrators Posted April 11, 2022 Sounds like it's working by preventing you getting a server that you don't want, I believe that is just the way Apex does their matchmaking, it doesn't continue to search or initiate a research on its own
