Broadband speed on r2
Max
Reboot the hub, wait 2 minutes, then reboot the R2, wait 2 minutes then see, sometimes they're particular about their boot order to get internet
  • Replies 69
I’m not using hub I’m using only this box and netdumar2
You were posting about the Smart Hub before that is using PPPoE, so plug that in then have the R2 plugged into that
I connected the Bt hub and r2 this is the results anything else I can do?
Disable QoS fully from the Congestion Control :menu icon and disable the protection options in WAN Settings then try again please
Could you disable IPv6 in LAN/WAN as well please, then reboot from the interface, wait 2 minutes and retry. Also are ALL devices connected to the R2 or are some connected to the hub now?
All devices connected to r2 ipv6 disabled and I can’t open any website
only netdumar2 interface it’s working
Ok so i did everything as above ipv6 disabled port scan off I also open dmz in Bt router for r2 so I have Nat type open all devices connected to r2 only and test was done with disabled qos
is it anything else what I can do to get maximum speed?
guys I’m not complaining 🤪just trying to get full speed if it’s possible
dawnload speed on r2 connection benchmark go up from 470 to 580 😎
Do you have any other devices you could test with at all? You're getting wildly varying results on different devices so I'm wondering if it might be limited by device on your PC for example. I think we've explored all settings avenues unfortunately.
I was thinking that to Unfortunately I don’t have any other devices for now
but thanks for all support and patience Fraser and all netduma team
best service online ever 😎
Sorry we couldn't get you any faster speeds at the moment, however, sign up for this: https://forum.netduma.com/topic/39415-introducing-early-access/ and then you can try a newer version once added and see if that helps at all!
Guys I have different problem now my r2 getting disconnected 4 times a day and sometimes it’s on but there is no WiFi signal 🤦‍♂️
so I have to do restart all the time
please advise
please advise
Could you make a post about it in the early access forum please?
Did you factory reset from the interface once the upgrade had completed?
Did the firmware fix your speed issue at all?
I didn’t got new firmware yet
do you want me to make a new post?
Oh right okay, try the new firmware, factory reset after and then see if either of the issues happen. If they do please make a new post in the early access forum - I have just given you access.
