LARRIIX Posted April 1, 2022 Posted April 1, 2022 I have problems pinging a computer on my team that is connected to the router, why is this?
Administrators Netduma Fraser Posted April 1, 2022 Administrators Posted April 1, 2022 How are both PCs connected, via WiFi if so 2.4 or 5GHz? Is there something specific they need to do together as that could help with the issue. Are you using a VPN?
LARRIIX Posted April 1, 2022 Author Posted April 1, 2022 They are both connected by LAN and I do not use any VPN and the problem is that I do not have connectivity of any kind nor can I use the network folders
Administrators Netduma Fraser Posted April 1, 2022 Administrators Posted April 1, 2022 You have no internet on these two PCs specifically or all other devices as well? I see you recently purchased the router, did you access the interface and complete the Setup Wizard in order to get internet?
LARRIIX Posted April 1, 2022 Author Posted April 1, 2022 If you'll excuse me, it was a configuration problem on my two computers. Thanks for your time
Administrators Netduma Fraser Posted April 1, 2022 Administrators Posted April 1, 2022 Glad to hear you got it sorted, thanks for the update!
