ryekye Posted February 19, 2022 Share Posted February 19, 2022 Needing help with qos for 502 download 24 upload speed and you guys should add auto setup to congestion control on xr500! Also should I use my r1 and use xr500 as ap for the features on it or would my speeds be bad on busy network? Link to comment Share on other sites More sharing options...
ryekye Posted February 20, 2022 Author Share Posted February 20, 2022 14 minutes ago, ryekye said: Needing help with qos for 502 download 24 upload speed and you guys should add auto setup to congestion control on xr500! Also should I use my r1 and use xr500 as ap for the features on it or would my speeds be bad on busy network? Plus is there anymore betas to test for xr500? Just curious I have a r1 and xr500 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 20, 2022 Administrators Share Posted February 20, 2022 What help do you need exactly? We are planning updates that will align the XR range more with what the R2 offers for example, including Auto Setup. That's entirely up to you and that would absolutely work fine. No beta versions currently available. Link to comment Share on other sites More sharing options...
ryekye Posted February 21, 2022 Author Share Posted February 21, 2022 12 hours ago, Netduma Fraser said: What help do you need exactly? We are planning updates that will align the XR range more with what the R2 offers for example, including Auto Setup. That's entirely up to you and that would absolutely work fine. No beta versions currently available. I have 502 down 24 up and was wondering if I need qos if so I'll enable it but having troubles finding sweetspot for the congestion control settings for connection I have a netgear cm1000 modem and xr500 hooked up don't know if I need to disable qos or not Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 21, 2022 Administrators Share Posted February 21, 2022 It's entirely up to you really, in terms of networking you can still absolutely get local congestion/lag with those speeds - it depends on what your network usage is like, are you often downloading/streaming when gaming? If so I would say to use QoS yes and to experiment with the Congestion Control percentages to see what feels best for you. If you don't and you're either gaming or downloading/streaming then you may not need to use it as much. Link to comment Share on other sites More sharing options...
ryekye Posted February 22, 2022 Author Share Posted February 22, 2022 12 hours ago, Netduma Fraser said: It's entirely up to you really, in terms of networking you can still absolutely get local congestion/lag with those speeds - it depends on what your network usage is like, are you often downloading/streaming when gaming? If so I would say to use QoS yes and to experiment with the Congestion Control percentages to see what feels best for you. If you don't and you're either gaming or downloading/streaming then you may not need to use it as much. I'll definitely use wired on Xbox and pc and test using ping plotter till I find sweet spot and until xr500 gets a update I may have to use my r1 but network is always busy and the r1 won't provide those speeds that I know of? Plus would r1 work with a busy network due to lower cpu on the r1? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 22, 2022 Administrators Share Posted February 22, 2022 The R1 likely won't be able to support those speeds no but it can handle a busy network no problem Link to comment Share on other sites More sharing options...
ryekye Posted February 22, 2022 Author Share Posted February 22, 2022 4 hours ago, Netduma Fraser said: The R1 likely won't be able to support those speeds no but it can handle a busy network no problem Ok I'll mess with ping plotter with my xr500 and find a good spot until u guys release the mobile update and new firmware Netduma Fraser 1 Link to comment Share on other sites More sharing options...
