guards_33 Posted February 5, 2022 Posted February 5, 2022 Devices connected to the wifi on the xr500 cant access some sites. The sites are online retailers its driving the misses crazy. all ports are open . I dont have any problem on the pc but its wired . Ive no idea how to fix it
Administrators Netduma Fraser Posted February 5, 2022 Administrators Posted February 5, 2022 Hey, welcome to the forum! That is certainly an odd one, did it work initially before you changed any settings? If so what settings have you changed since then? As a test disable QoS from the Congestion Control menu and see if that allows it to work please.
guards_33 Posted February 5, 2022 Author Posted February 5, 2022 Thanks for the suggestion, That worked for most devices while others still couldn't access some sites. Never the less this doesn't matter as main devices can still be used. I now have encountered a separate problem whereas when i load my VPN into hybrid, it disconnects intermittently after just a few minutes and doesn't save credentials. I have tried PUREVPN using the built in account login, and PROTON VPN (using advanced config) i get the same outcomes. vpn works initially but then after a few minutes i lose connection briefly and then connection status on Hybrid vpn is failed. and i am back to not having a vpn enabled.
Administrators Netduma Fraser Posted February 5, 2022 Administrators Posted February 5, 2022 Interesting, though if you want to use QoS then that poses an issue. Could you provide the config you're using manually? How have you added the device to the VPN? Did you enable block traffic if the VPN is disconnected?
