gando70 Posted November 21, 2021 Posted November 21, 2021 Hi, after a weekend spent doing installations on installations, I don't know what to think anymore.son started from FW.DumaOS-R2-Soft-Launch-3.0.179-2-211020.sig that Fraser sent me to solve the problems connection. I do the update, factory reset, and change the address to the router, start setting the addresses, customize the dashboard etc. etc. and everything seems to work until I lose the connection. I try to go inside and it is impossible. I turn off and try again and the problem reappears. I do a reset, I exclude all peripherals except the PC and I lose the connection. Again reset, I keep ip start reconfiguring and the problems begin again. Exasperated I go back to the starting fw (DumaOS-R2-Soft-Launch-3.0.179-2-211020) and I find the new surprise, I have no more blocks for a few hours, but the qos is no longer reloaded. New reset I go back to R2: 3.0.394 and the qos works but the problems recur. Now I don't know what to think ... is it my R2? that the fw has bugged my router ... sky wifi (italy) that is messing with the connection. The fact is that both with a fw I have problems and with the new one I don't stay connected.
Administrators Netduma Fraser Posted November 21, 2021 Administrators Posted November 21, 2021 Just to clarify, after .394 was installed you did a factory reset as well and it still occurred? Do you have access to the interface when it happens? Is it both wired and wireless devices?
gando70 Posted November 21, 2021 Author Posted November 21, 2021 I performed a factory reset, I also pressed the button next to the power supply. all the connected devices are wired, for Wi-Fi I use a second network not connected to the R2. when this happens I lose access to the interface. if it remains open it appears to be blocked.
Administrators Netduma Fraser Posted November 22, 2021 Administrators Posted November 22, 2021 What is your exact physical setup and their models? E.g. modem > R2 > other router Do you require PPPoE, VLAN, DHCP identifiers for a connection? How often does the issue seem to occur and is there any pattern to it happening e.g. when network is using a lot of traffic etc
gando70 Posted November 23, 2021 Author Posted November 23, 2021 here I am after a lot of testing and I still don't understand. I have a ftth sky wifi, ONT Huawei HG8010H, fritzbox 7530, R2, and to cover the whole house with WiFi Tenda WiFi Mesh Nova MW3. the problem occurred randomly while I was configuring the wifi mesh, while I was doing the network tests of the playstetio or the xbox. The strangest thing is that last night after I was contacted by Sky to warn me that the MAP-T protocol will soon be active and therefore I will be forced to use their router, even the fritzbox had problems (voice line disconnected and reconnected ) I restart ONT restet factory R2 configured xbox and playstation and since then no disconnection. tonight I entered the mesh network and no problem. Now the weird thing is that the fritzbox has never reported network failures, is Sky doing tests? Could they have disturbed R2? The fact is that after the ONT restart (no error LEDs lit) everything started to work. ,Can the future map-t protocol give problems? In Italy no operator is using it, in England is it already active? Apart from the sky box for now very few routers support it and netgear and fritzbox do not have compatible models
Administrators Netduma Fraser Posted November 24, 2021 Administrators Posted November 24, 2021 Interesting, I've not actually explicitly heard anything about that so I couldn't say for certain whether it would cause you any issues but from what I read it will be more beneficial for you. Thanks for the update, do let us know how you get on, it would be very interesting if that resolved the issue and perhaps something for the team to research more on.
gando70 Posted November 24, 2021 Author Posted November 24, 2021 in reality I don't know if it is more advantageous, from what I read they associate your ip v4 to other 15 users with translations from ipv4av6 according to the needs. for sure I will have to use the Skybox. https://www.dday.it/redazione/41083/sky-wifi-sempre-piu-ipv6-ecco-cosa-cambia-per-gli-utenti quest’articolo(in italiano) spiega un po’ di cose su questo protocollo
gando70 Posted November 27, 2021 Author Posted November 27, 2021 unfortunately here I am again, I thought that the problem was due to the new configuration of Sky Wi-Fi and it invests I was proved wrong. from despair I exhumed my old xr500, installed the latest firmware connected all the cables put the ip I had on the R2 and I have not had a disconnection for 3 days.I can't understand what's wrong, disconnections are always random. while I configure, while playing while watching a movie, or in the middle of the night. while nobody is using the network. the fact is that the network LED is on, but the network is not you log in to the r2 interface and you don't browse. you unplug it wait a bit and it works pawn on the next crash. I'm afraid it's the hardware (purchased on day one) worked fine with the native fw, this summer it has started giving some problems but it was solved with the fw eh Fraser sent me and after this update it became completely useless.
Administrators Netduma Fraser Posted November 27, 2021 Administrators Posted November 27, 2021 In DHCP settings change the lease hours to 168, change the start of the DHCP range to .50, then give reserved IPs to devices between .2 - .49, then reboot the router, wait 2 minutes and see if it is more stable after that
gando70 Posted May 23, 2022 Author Posted May 23, 2022 hello, I wanted to know if there are any news coming out, unfortunately the problems on R2 continue to present themselves.Unfortunately, being always frequent I had to remove the router.I use it only when I play a few games but it is really difficult to manage the situation.Many times I am forced to unplug the power plug to be able to restart it. I am always hoping for a stable version that will solve the problems
Administrators Netduma Fraser Posted May 23, 2022 Administrators Posted May 23, 2022 47 minutes ago, gando70 said: hello, I wanted to know if there are any news coming out, unfortunately the problems on R2 continue to present themselves.Unfortunately, being always frequent I had to remove the router.I use it only when I play a few games but it is really difficult to manage the situation.Many times I am forced to unplug the power plug to be able to restart it. I am always hoping for a stable version that will solve the problems If you sign up here then once we provide access you can try a new firmware to see if it resolves your issues: https://forum.netduma.com/topic/39415-introducing-early-access/
Administrators Netduma Fraser Posted May 24, 2022 Administrators Posted May 24, 2022 7 minutes ago, gando70 said: thx,I hope to receive access soon You have been given access so take a look at the sub forum: https://forum.netduma.com/forum/144-netduma-r2-early-access/
