II Z IE IR O II Posted January 8, 2015 Posted January 8, 2015 Is the wifi led suppose to flash to indicate that the setting for wifi is enabled? Just wonder because mines doesn't flash which to me, indicates that wifi has been disabled but infact it is enabled.
BL4CK OPS V3TRN Posted January 8, 2015 Posted January 8, 2015 Same here mine has never flashed or even Illuminated . But the wifi is on
II Z IE IR O II Posted January 8, 2015 Author Posted January 8, 2015 Same here mine has never flashed or even Illuminated . But the wifi is on I'm glad I'm not the only one! These are the little things that irritate me. LOL
abc123 Posted January 8, 2015 Posted January 8, 2015 this is likely a simple led toggle that was missed in coding...Speaking in code would be the only way to explain it all...and i'd rather not. Too sleepy for that, instead let me just say this isn't a hard fix and i'll be passing the details to Iain...Personally I don't like LEDs
Guest Netduma_Iain Posted January 8, 2015 Posted January 8, 2015 Probably minor bug, don't worry it makes no difference Other than aesthetically
II Z IE IR O II Posted January 8, 2015 Author Posted January 8, 2015 Thanks! I thought mines was broken. Didn't wanna give it up if it was! LOL
