skram Posted August 11, 2021 Posted August 11, 2021 Just received my R2 got everything plugged in, set up and updated firmware to 3.0.205. Log in to DumaOS on firefox and the main dashboard I can only get Network Status and Traffic Overview to load. The other boxes just load then I get a "Error: This Rapp is not loaded yet, please try again in a minute." Click on geo filter tab and it loads and loads and loads and loads then pops up the map then the same error listed before. I can click the X on the error pop up and close it then it pops back up 8 times before it finally goes away and I can pick my location. Once I pick my location (No matter where I choose) my geographical region in game is always my city/state. Seems like everything on this dumaos just loads for ever and gives that error. I've tried rebooting the router from DumaOS. Unplugged, waiting 30sec-1minute and plugging back in. I've tried factory reset and start over.
Administrators Netduma Fraser Posted August 11, 2021 Administrators Posted August 11, 2021 Hey, welcome to the forum! Did you access the interface quite quickly after plugging it in? It can sometimes take about 2 minutes for the Rapps to load correctly so reboot from the interface, then don't access it for 2 minutes, after that it should all be loading. It's not a VPN so it doesn't change the region you appear from but you can still use it to force the servers you want to play on.
