faceman469 Posted June 6, 2021 Posted June 6, 2021 Signed up for pure vpn to add to my r2. Added my Xbox series x to try out cod mw with the vpn. I have a 1gb internet connection and with the vpn on I'm getting 2mbs on Xbox live. I lag so hard that I can't even shoot my gun in multiplayer. Tried UDP and TCP from both servers closest to my home. I only have 5 days left on the trial to figure this out. Any help would be appreciated
Administrators Netduma Fraser Posted June 6, 2021 Administrators Posted June 6, 2021 Hey, welcome to the forum! That is due to the fact it is OpenVPN and hardware limitation, although you should be getting higher than that. If you disable QoS does it improve? That speed is fine for gaming as it won't even use half of that, using a VPN in general increases latency so if it's not needed I wouldn't recommend it.
faceman469 Posted June 6, 2021 Author Posted June 6, 2021 Just tried your suggestion but still unplayable.
Administrators Netduma Fraser Posted June 6, 2021 Administrators Posted June 6, 2021 If you disable the VPN does the game quality increase again?ย
faceman469 Posted June 6, 2021 Author Posted June 6, 2021 Yup when disabled it works perfectly. Just wanted to try the hybrid vpn because I thought it would make a good thing better. Well it only cost me .99 cents๐
Administrators Netduma Fraser Posted June 6, 2021 Administrators Posted June 6, 2021 Are you playing over WiFi or ethernet when using the VPN? If you prioritize the device using Traffic Prioritization is it better at all? What speeds do you get if you apply it to a PC?
faceman469 Posted June 6, 2021 Author Posted June 6, 2021 I'm hard lined into Xbox from r2 . I've tried it with Xbox prioritized and with Qos disabled.speeds are poor no mater what I due and latency is through the roof. I also download the pure app straight into my t3 android tv box to see if that was better and could barely stream IPTV service.
Administrators Netduma Fraser Posted June 6, 2021 Administrators Posted June 6, 2021 Can you try a different server just in case there is something weird going on with the one closest to your home and see if there is an improvement?
faceman469 Posted June 6, 2021 Author Posted June 6, 2021 Tried several and all were slow for me. I'm just going to stick with my normal vpn service. Straight from the router seems to slow performance down.
Administrators Netduma Fraser Posted June 6, 2021 Administrators Posted June 6, 2021 Could you post the config you're using? Maybe I can spot something causing it to be slower than necessary.
faceman469 Posted June 7, 2021 Author Posted June 7, 2021 Appreciate it but I've already cancelled the service. Didn't want to get charged for the two years and I tend to forget the cancel part. Will try again at a later date. Thanks for the help.
faceman469 Posted June 12, 2021 Author Posted June 12, 2021 Appreciate it but I've already cancelled the service. Didn't want to get charged for the two years and I tend to forget the cancel part. Will try again at a later date. Thanks for the help. Update: Ok so I read through these forums and figured out how to put "ipvanish my preferred vpn"ย onto the "R2 my preferred router" and it's working great. I do get some lag here and there but it seems to go in my favor. Sometimes I move at normal speed and my opps move in slow motion ๐. But I would like to try Tcp or Ikev2 in the protocol. If I change next to proto where it say udp to tcp or Ikev2 will that change the protocol in the configuration ?
Administrators Netduma Fraser Posted June 12, 2021 Administrators Posted June 12, 2021 Could you explain how you set them as preferred? Yes that will work for TCP definitely, ikev2 won't work as the VPN only supports OpenVPN currently.
faceman469 Posted June 12, 2021 Author Posted June 12, 2021 2 hours ago, Netduma Fraser said: Could you explain how you set them as preferred? Yes that will work for TCP definitely, ikev2 won't work as the VPN only supports OpenVPN currently. I didn't set it as preferred. It's just my preferred vpn service๐ Thanks for confirming how to change to Tcp in the configuration text. I never would have figured out how to get ipvanish working on the router without these forum's๐๐พ
Administrators Netduma Fraser Posted June 12, 2021 Administrators Posted June 12, 2021 Silly me!ย ๐ย You're very welcome!ย The forums are a great place for sharing knowledge, glad it helped!
