Qais Posted May 24, 2021 Posted May 24, 2021 Hello, it seems odd that certain users iphone users at home lose their wifi connection frequently on XR500 however other devices including iphones does not facing this issue... one of the iphone user changed her iphone to latest one for another reason but issue still followed her, so issue not from iphone. After i been theough my investegation about this problem i found that once i saw on the iphone wifi setting to that wifi connection it changed regular IP to different type barely noticed but looks like 169. Somthing... further search at router setting exactly at device manager, those who having this issue of loosing connection are assigned to more than three IPs but mac adress is only at one IP in front of it... offcourse ISP modem restarted and XR 500 as wll, but issue still there please help
Newfoundland Posted May 24, 2021 Posted May 24, 2021 Hi, first off is your 5Ghz channel set to 80Mhz?
Qais Posted May 25, 2021 Author Posted May 25, 2021 I never came across 80Mhz expression on the router settings!?
Newfoundland Posted May 25, 2021 Posted May 25, 2021 It’s under WiFi settings. Check the 160Mhz is not selected. That can create issues as iPhones don’t support it.
Administrators Netduma Fraser Posted May 25, 2021 Administrators Posted May 25, 2021 On the iPhone itself, in WiFi settings, click the i icon on the router WiFi and if Private Address is enabled, disable this, then see whether the disconnects stop. You may need to disconnect from the WiFi and reconnect to it to make sure it works.
