Wifi speeds > wired speed with cat8 cable
BingBONG
Im getting about 200mbps download on wifi and only 10-12mbps download on my wired connection which is a cat8 connection to my desktop. Is there something that I can do to fix this?
When i run connection benchmark via the DumaOS, i have my normal speeds, around 766mbps. when i test the connection to the computer (connected to the R2 via Cat8 ethernet) its only ~12 mbps. QoS is disabled
Go to the Device Manager click the :menu icon and select the table view then provide a screenshot of what you see please?
By QoS disabled do you mean from the Congestion Control menu?
