RonBurGz Posted May 15, 2021 Posted May 15, 2021 I noticed my poe (verizon router to r1) link speed is 1000 mbits but for port 2 ( r1 to pc) its at 100mbits. I run speed tests and my up and download speed stay at around 100mb up/down. How do i go about fixing this. Thanks in advance Firmware Version2.1.3.29 DumaOS Version1.3.29
Administrators Netduma Fraser Posted May 15, 2021 Administrators Posted May 15, 2021 That will be the ethernet cable you're using that is limited to 100Mbits, either the one you have is faulty or you need one that is at least Cat5e. Once it's replaced with a cable that can support those speeds it should work
