DaveCOP Posted May 2, 2021 Posted May 2, 2021 Hi, so ive been using my router and its ok. However, i want to get ride of my BT HUB, is it worth selling my duma router on ebay to get rid of it and buying this instead? I dont want to have FIBRE > BTHUB > DETDUMA > PS5 i want to achieve: FIBRE > NIGHTHAWK > PS5 However, this one seems to have the DUMAOS built in? https://www.amazon.co.uk/NETGEAR-XR500-Nighthawk-Gaming-Router/dp/B01MY96ENS/ref=sr_1_5?dchild=1&keywords=gaming%2Brouter&qid=1619963759&sr=8-5&th=1 Will this work to achieve what i want?
Administrators Netduma Fraser Posted May 2, 2021 Administrators Posted May 2, 2021 Any router, needs to be connected to a modem/router to get internet or from a point in the wall with an ethernet connection so if you get rid of the BT hub you may have to get a modem to replace that so you'd still have two devices there and have paid more than needed
DaveCOP Posted May 2, 2021 Author Posted May 2, 2021 No, the BT HUB is a router, it connects into the white fibre box on the wall which is the modem. Ive read on the bt forums, lots of people have replaced there BT HUB for a gaming router and enabled the pppoe. Solved: Re: Using my own router instead of BT Hub for BT F... - BT Community Im hoping this https://www.amazon.co.uk/NETGEAR-XR500-Nighthawk-Gaming-Router/dp/B01MY96ENS/ref=sr_1_5?dchild=1&keywords=gaming%2Brouter&qid=1619963759&sr=8-5&th=1 replaces the BTHUB, so i can get rid of the BTHUB and NETDUMA, as the nethawk as the DUMAOS built in
Administrators Netduma Fraser Posted May 2, 2021 Administrators Posted May 2, 2021 In that case yes you can do that and it will work
