Netduma Liam Posted April 26, 2021 Posted April 26, 2021 Yes, if you go to System Information in DumaOS you'll be able to see the WAN IP under 'Network Status'. This should match what you see in the Sky Hub and is also the IP address that should be in the Sky DMZ. We are actually going to be pushing an update for Halo today as we've also noticed some issues, that should help with your issue!
8 Wonders Posted April 26, 2021 Author Posted April 26, 2021 Hi Liam ive set the wan ip from netduma network status as a reserved address in the sky hub LAN TCP/IP Setup, to do that i then selected netduma under address reservation with the wan ip from network status does that sound correct? thats great news, is this something that will automatically be put in place or do i need to download an upgrade file? thanks again
Netduma Liam Posted April 27, 2021 Posted April 27, 2021 That sounds good to me, just make sure that IP address is also now in the Sky DMZ and that should be fine. You won't need to download anything, it should be done automatically.
