Loss of wire speed
LARRIIX
Hello good, I comment my problem. It turns out that I have contracted a 600 megabyte fiber optic when I connect the cable to the computer it gives me 600 without a problem but when I use the netduma R1 I have a speed loss and I only get to 250. How can I solve it? Thanks in advance.
You will need to disable QoS completely from the Anti-Bufferbloat/Congestion Control 3 line option menu - it is unlikely you will be able to reach those speeds while using QoS.
it's perfect, the problem is that I can't find the option to disable it
Go on the QoS page then on the top left of the Anti-Bufferbloat/Congestion Control click this icon :menu and then click disable QoS.
Ah, it's worth a lot, thanks, it's going to perfection for me
