_DuzY_ Posted March 28, 2021 Share Posted March 28, 2021 Hello, since yesterday i have problems with download speed on my netduma. Speed is ~ 200Mb smaller than my isp router. I've tried everything and nothing works. Link to comment Share on other sites More sharing options...
Newfie Posted March 28, 2021 Share Posted March 28, 2021 I take it QoS is completely off ie no congestion control. it’s in the ball park regarding the speed, some seem to hit more some less. what’s your setup, the more info the better to see if this can be improved? Link to comment Share on other sites More sharing options...
_DuzY_ Posted March 28, 2021 Author Share Posted March 28, 2021 I have QoS on Off and no congestion control When i connect PC directly to ISP modem everything is fine. Stable 1Gb/s all the time with no spikes At the beginning evertyhing Was fine. The problem appeared yesterday. WAN DHCP WAN General Settings all off QoS off Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 28, 2021 Administrators Share Posted March 28, 2021 What is the model of your ISP modem? Are ALL devices connected to the R2? Link to comment Share on other sites More sharing options...
_DuzY_ Posted March 28, 2021 Author Share Posted March 28, 2021 My ISP modem is Giga Connect Box. For the test i have connected only my PC Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 28, 2021 Administrators Share Posted March 28, 2021 Thanks for that, how have you set that up to allow an Open NAT to the R2 and devices behind it? I would suggest connecting all to the R2 or at least disconnecting them from the Giga and trying again Link to comment Share on other sites More sharing options...
_DuzY_ Posted March 28, 2021 Author Share Posted March 28, 2021 For now my connection is ISP modem(bridge mode)->Netduma->PC All devices are disconnected. Netduma has problem to reach full bandwidth. Download speed can't get over 850 Mbps Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 28, 2021 Administrators Share Posted March 28, 2021 So it can get 850 like that? If so that is great, that will be roughly the maximum you can get I think, we only got a little higher in a lab environment Link to comment Share on other sites More sharing options...
