How does "Mirror Settings on both 2.4Ghz and 5Ghz" work
Mitch
Hello,
I tried to look up any topics regarding the mirror settings for wifi, what is the concept behind this? say I select my network on my device and it picks up the ideal band 5Ghz upon connection, will the system dynamically switch me to the other band once is start walking into the farthest side of the house away from the router?
So yes distance will play a part, if you go further away from the router it is likely to connect you to 2.4GHz and it will decide which to use depending on the bandwidth need of the device.
