Pokemon Shield + Mario Kart best settings for Nintendo Switch
Cajun72
Hi Guys
Just wondering if there are recommendations for these 2 games on the Nintendo Switch, e.g. is it best to port forward, and geo filter settings etc.
Loving these games..so would appreciate any advice particularly for max raid battles where players join on pokemon shield
Currently on FM R1 3.0.171
Thanks in anticipation
Theoretically, you could add you Switch to Geo-filter and select 'Choose Manually', then see if it identifies/blocks game servers, though it's untested so I'm sure whether it'd work or not.
What are you looking to do on Pokémon? What's the intended result?
I've already added the switch to the Geo-filter.
The main reason is to connect easier with other players when searching for a max battles. A total of four players including yourself can join. Currently it's hit and miss - sometimes finds only one other player, other times you get lucky and get 2 or even 3. Just wondered if the settings need adjusting? There seems to be alot of players wondering around in the wild area so no shortage of online players.
OK sure, that's interesting. I guess you could set your Geo-filter radius really wide to accommodate for as many servers/peers as possible? That being said, this won't be much different to just not having Geo-filter enabled at all.
