Using vpn with smart tv
l2eactionz
If you have a VPN subscription with a provider you can set this up with Hybrid VPN and apply the VPN to the entire device so that you can achieve that.
Okay cool is there a vpn you would recommend and once it's on the router will that set to my chosen location sorry never used vpn
We don't have any particular recommendations for VPNs. It depends which one you use - we have basic setup compatibility with HideMyAss and PureVPN - so you enter your username/password the provider has given you and select the server country and location. If you want to use another provider you would obtain the configuration file for the particular server you want and enter that into the router.
Okay perfect I've just come across the netgear tutorial as well
