Network Monitor and Snapshot display issues
Modem / Router Firmware LH1000 - 0.12.15r
Duma OS version - 3.0.167
I found an number of anomalies, can you advise if these are intentional or bugs?
Duma OS is running stock (post reset), no changes.
The Telstra user manual - Game Optimiser User Guide (telstra.com.au) appears to not have these issues in the Network Overview / Monitor screenshots.
Is there a newer version of Duma OS or do I need to make any adjustments here?
Network Snapshot
* Shows downloads counted in fractions of Mbps
* Graph X axis is missing when there are a large number of devices connected
(refer to Network Snapshot.jpg)
Network Monitor
* Downloads are being counted in fractions of Mbps, was downloading at approx 20Mbps at the time
(refer to Network Monitor 1.jpg)
* Uploads are counting ok in integers
(refer to Network Monitor 2.jpg)
When you hover over the line or bar graphs it should give an accurate view of how much it is down/uploading. If it's more than that then it's not reporting correctly. Do you mean the X axis disappears when X amount of devices are shown or when a certain amount of bandwidth is used? Thanks for letting us know, I will let the team know so they can have a look.
