NetDuma R2 problems
Shidar0
Hello i just got my netduma R2 the 24th of december , set it up and tried to connect , when i plugged my ethernet to the slot 1 my pc told me "connexion 2 no internet" or something like that.So i tried the port 2 and it finally was connected but when i tried to go to DumaOS/192.168.77.1 or going to any site google did not wan't to connect because of some firewall problems or that google can't connect because my web adress has changed .Then i tried to connect to wifi but the password was for some reason false i tried to type it in at least 20 times and it still didn't work.
Can someone help me fix that problem and make the NetDuma R2 work normaly thanks.
PS sorry if my english is bad.
Sorry to hear you're having this issue. Just to clarify, are you able to access the interface? The reason you have no internet is because you need to go through the setup wizard on the interface first. If you can't access the interface could you open command prompt on your PC, type
ipconfig
and then press enter and provide a screenshot of the results please?
You don't need internet to access the interface as it is a local address. The IP your computer is getting is not the same as I would expect if you were connected to the R2. Was the PC definitely connected to the R2 when you did that screenshot? If you try to access 192.168.5.1 in a web browser what do you see?
No worries! Thanks for that, okay could you now take a screenshot of what you see when you access 192.168.77.1 please?
Yes exactly, brilliant to hear it's working now. Any other issues/questions let us know and we'll be happy to help.
Happy holidays!
