Xr1000...qos speedtest and connection benchmark problems...
Hi,
I have problems with the speedtest ... in auto detect it signals me download speed at 70/80 mb, while for upload everything is ok. same thing in connection benchmark, where at ping test it shows me a download speed 10 times lower. I deactivated the qos, I checked on the device manager, on the connection status and it correctly reports the maximum of my line (1000 downloads / 100 uploads) depends on what? the firmware is updated to the latest version available on the official website.
The Auto Speed test and Connection Benchmark speed test are reporting lower than they should at the moment but we will be improving upon that. If you do a speedtest.net test for example your router will be getting the expected speeds. So make sure to enter the speeds you actually expect, not what auto speed test says currently.
