dr_leh1 Posted November 10, 2020 Posted November 10, 2020 good day any idea guys how can i adjust my ping test to make it better thanks
wilsonbx198st Posted November 10, 2020 Posted November 10, 2020 are you wired, wireless? that ping is pretty high
dr_leh1 Posted November 10, 2020 Author Posted November 10, 2020 20 minutes ago, wilsonbx198st said: are you wired, wireless? that ping is pretty high im wired i know its 2 high
wilsonbx198st Posted November 11, 2020 Posted November 11, 2020 well first off whos your provider ? what type of ethernet cables do you have and modem type that all plays a huge roll ,also did you have similar ping before changing to the R2?
XvZ Posted November 11, 2020 Posted November 11, 2020 2 hours ago, wilsonbx198st said: well first off whos your provider ? what type of ethernet cables do you have and modem type that all plays a huge roll ,also did you have similar ping before changing to the R2? Does changing modem from ISP provided modem improve ping?
wilsonbx198st Posted November 11, 2020 Posted November 11, 2020 yes, i changed my modem and ping overall is but more stable but before you change modem make sure the modem you plan to get is compatible with your isp
dr_leh1 Posted November 11, 2020 Author Posted November 11, 2020 10 hours ago, wilsonbx198st said: well first off whos your provider ? what type of ethernet cables do you have and modem type that all plays a huge roll ,also did you have similar ping before changing to the R2? my provider is stc im living in saudi arabia cable taypes cat 6 and 7 isp modem is huawei hg4285q net type is fiber and yes i had similar ping before on netduma r1
dr_leh1 Posted November 11, 2020 Author Posted November 11, 2020 8 hours ago, XvZ said: Does changing modem from ISP provided modem improve ping? yp ping improve only little
Administrators Netduma Fraser Posted November 11, 2020 Administrators Posted November 11, 2020 Considering your average ping, your Ping Under Load test is basically as good as it can get. I imagine it's so high because it is pinging 8.8.8.8 (Google), I imagine if you use speedtest.net for example it will show a lower ping. As it seems like your QoS settings are optimized you can ignore it.
