kesanmits48 Posted November 10, 2020 Posted November 10, 2020 Looking at possibly purchasing this new Mesh system, but I have a few questions: 1- Does the Nighthawk app show throughput speeds and data for wired and wireless devices? or wireless only? 2- Does it allow device priority 10.0.0.0.1 192.168.1.254 for wired and wireless device? or wired only? 3- Does the mesh system support Ethernet back haul? AP steering and band steering? Moving from Amplifi Instant which I've had only a few days and they're honestly worse than my old Google WiFi. TIA!
Administrators Netduma Fraser Posted November 10, 2020 Administrators Posted November 10, 2020 Hey, welcome to the forum! As this isn't a Netduma/DumaOS supported product I would recommend you post here: https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders In order to get the most accurate answers to your questions.
Newfoundland Posted November 10, 2020 Posted November 10, 2020 You could get the XR1000 and EAX80. The EAX80 uses a backhaul and both offer what’s called smart connect. Might be something to consider and is a full WiFi 6 system with great coverage if you wanted a gaming router setup.
