help for xr500
hello I would like to configure my xr500 on converter I explain there is my internet after there is the converter after I have a switch tp link sg105 so my question is the following: someone could give me the procedure to follow for that all this little world works together wan side lan side then the parameters for xbox one and for pc here thank you.
You can't do it that way. You will need to do internet > converter > XR500 > Switch and then it will all work together optimally.
thank you for your quick answer i will do that. By the way there is nothing to do on the wan side of the fixed ip or something else and on the lan side enter the identifiers in the console?
Unless you require DHCP identifiers or anything like that in order to get a connection then no but if you do then you would enter it into the XR settings.
ok i will try its waiting to keep you updated thank you for your time
