My download speed seems to be capped at around 12mbps but I have connection for 225mbps
-Siddhu-
Hi,
I noticed my download speed was stuck at 1.4 MB/s while downloading the latest update for Call of Duty Modern Warfare. I initially thought the speed was throttled by battle.net.
Now I tried downloading RDR2 and I still have the same issue.
My speedtest result is good but every download is slow. I tried torrenting, downloading from google drive.
I tried changing the QoS settings and I finally factory reset the router but the issue is still present.
If you disable QoS fully in the Congestion Control 3 line option menu in the top left of the panel and then attempt a download, what do you get?
I have my ISP modem is in bridge mode  and I setup PPPoE in the R2. all devices are connected to the R2. Only my PC is connected via ethernet, all other devices use wifi.
If you take the ISP hub out of bridge mode, remove the PPPoE details from the R2 and then try downloading, is it faster?
I removed the isp router from bridge mode but the speed still capped at 12 mbps.
I connected my PC directly to the ISP modem to check and the speed is around 90 mbps.
Put the R2 in the Hub DMZ. Also check to see if there are any firewall settings on the hub, if so please disable those and then check the speed again.
I did a bunch of reboots and put the ISP Hub back to bridge mode and the speed randomly went back to normal. I am not sure what was causing the issue.
I'll let you know if the issue returns.
thanks.
Update: problem returned
I connected my PC via Wifi and the speed are fine, only ethernet seems to have some issue.
Did you try plugging the ethernet cable into another port? Someone previously said they had issues with port 2.
I tried all 4 ports, the speed is still capped
Yeah, I tried using another Ethernet cable. I don't think the cable is the issue, I get 100mbps when I connect my pc directly to the ISP Hub.
@Netduma Fraser any other suggestions? I have attached a pic showing the 1gbps speed with the r2. I don't think the cable is the issue. Please help, I spent hours trying to solve this.
As an experiment make a Traffic Prioritization rule for the PC:
Source: 1 - 65535
Destination: 1 - 65535
Protocol: TCP/UDP
Do you get higher download speeds then?
I tried this and the ethernet speed is still stuck at 12mbps.
I tried few combinations to find out what is causing the problem. USB-C adapter is giving me 200mpbs
ISP hub to PC via ethernet - 100mbps download
ISP hub bridged to my old d-link router to PC via ethernet - 100mbps download
ISP hub bridged to R2 to PC via wifi - 200mbps
ISP hub bridged to R2 to PC via ethernet - 12 mbps download
ISP hub bridged to R2 to PC with usb-c ethernet adapter - 200mbps
With the rule I gave you to do, if that doesn't work then there is an issue outside of the router. Looks like you have found it in that the built in ethernet on your PC is not able to do more than 100Mbps which is why the adapter worked better.
