problem with hybrid vpn
Hey,
i installed an router xr700 and try use hybrid vpn
But connecting and in logs is reseting
what can do for working
Just to clarify, it isn't connecting with PureVPN? Are you using the basic setup or the advanced with PureVPN configuration files?
Hey,
try use basic with purevpn and logs reseting
tryed advanced to same thing.
But use now surfshark working
strange with purevpn
what i do use surfshark have account for surfshark vpn
have that too purevpn
Hey,
no says connecting and when looking in logs is reseting try connecting.
But that working with surfshark filled in advanced
use purevpn on another router working great.
use firmeware 1.0.1.20
will watch that later
Hey,
yes tryed norway, denmark(showing belgium)germany same problem
and tryed use advanced an ovpn fil from purevpn.
Strange is that an bug in xr700 perhaps?
Hey,
I have decided use surfshark on my router is working, have purevpn on another router not netgear.
Thanks for letting us know, we will be continuing to try and improve the feature and keep up to date with the configs.
Hey,
strange my connection to surfsharks was failed but tryed then purevpn same thing tryed connecting and in logs info there reseting.
used surfshark again then could connect again.
why happen that when use purevpn how can fix that problem tryed different place to connect but same problem says connecting and logs info reseting self
hybridvpn not working , removed my computer then working internet for me.
see screenshots
Just to be clear, using the same configuration as previously it disconnected on its own and this was the error you received?
Add the line:
keepalive 10 30
to your configuration file and save it and see if it sustains a connection.
Hey,
where add that end of that configuration file.
No used basic
and strange when use typ server denmark and city will that show belgium talked with purevpn they not understand.
perhaps try use belgium will that show denmark
Hey, very strange tryed use another vpn provider use advanced settings
tryed connecting to belgium is belgium
use ivacy vpn and connecting to denmark when use ipleak or iplocation says belgium
changed to sweden and says sweden but when check ip is sweden but server purevpn have they same server place!!
You can add that part somewhere in the initial section under auth user pass. Sorry, I'm not sure I follow. When you're using the Advanced Setup and have selected a country it is showing as though you're in another country? The web browser may be caching the previous location so test in an incognito window.
