Baturi Posted August 23, 2020 Posted August 23, 2020 So i have 1000/50 plan i always set my sliders 70/70 or 50/70 and when ever a device is using upto about 50,70,100+ MBPS Of download my Game on PS4 starts to get real weird Abit of lag pikes i can go even lower with my sliders but i also don't wan't to cap over 100+ MBPS of QoS sliders so each device can have their own treat with high speeds what is the best way possible to lower the lag spikes without causing problems to other devices
Administrators Netduma Fraser Posted August 23, 2020 Administrators Posted August 23, 2020 Are you using Traffic Prioritization? That will put your gaming packets ahead of the network queue and so will eliminate jitter/packet loss.
Baturi Posted August 23, 2020 Author Posted August 23, 2020 51 minutes ago, Netduma Fraser said: Are you using Traffic Prioritization? That will put your gaming packets ahead of the network queue and so will eliminate jitter/packet loss. yes i am using it i have it auto enabled. my household don't usually use high bandwidth but today definitely kicked in with all those settings applied the experience wasn't too bad it was okay. will their be any difference if i manaully put my device and other Gaming Devices in the house or just go with DumaOS classified games
Administrators Netduma Fraser Posted August 23, 2020 Administrators Posted August 23, 2020 If you want just one specific device to have priority I would suggest disabling DumaOS Classified Games and adding the one console manually with the Games Console service.
