patnj Posted August 21, 2020 Posted August 21, 2020 When disabling a specific device, there is nothing to show (e.g. the Disable button does not change to Enable) that the adblocking for the device has been disabled, except that you notice that it is no longer showing any ads, tracking, etc. from being blocked. Equally, I cannot see a way to re-enable Adblocking for a previously disabled device. How do you re-enable adblocking for a specific device ?
Administrators Netduma Fraser Posted August 21, 2020 Administrators Posted August 21, 2020 We will actually have that fixed for the next firmware. For now what I would recommend is pause if for one minute then click the play icon and it should start blocking again, does that work?
patnj Posted August 21, 2020 Author Posted August 21, 2020 Yep...work around is working 😊 Do you have an update on when the new firmware will be released ? I'm currently running R2 3.0.129 (I believe this was a hotfix RC candidate version)
Administrators Netduma Fraser Posted August 21, 2020 Administrators Posted August 21, 2020 21 minutes ago, patnj said: Yep...work around is working 😊 Do you have an update on when the new firmware will be released ? I'm currently running R2 3.0.129 (I believe this was a hotfix RC candidate version) Great to hear that! We're working with some users who have expressed some issues that we think everyone will benefit from receiving the fixes for so we're holding off slightly but I don't think it will be too long.
