Jamiesc19 Posted August 9, 2020 Posted August 9, 2020 What’s the difference between the 2? They sound like they do exactly the same thing as each other
pollutionblues Posted August 9, 2020 Posted August 9, 2020 Filtering mode means that the geofilter is on, Spectating mode is off. Strict mode ensures that you only connect to servers that are inside of your radius, disabling strict mode is only needed for specific games like Destiny 2.
Administrators Netduma Fraser Posted August 9, 2020 Administrators Posted August 9, 2020 As above, just to add a bit more information, strict mode off will allow some servers outside your radius to be allowed but will block peers outside your radius. Wouldn't suggest for anything other than Destiny.
Jamiesc19 Posted August 9, 2020 Author Posted August 9, 2020 For example if I had strict mode unticked and filter mode on wouldn’t that not do the same thing as have strict mode ticked? Without filter mode would Geofilter not work? I’m just getting used to it
Administrators Netduma Fraser Posted August 9, 2020 Administrators Posted August 9, 2020 Spectating Mode: Does not restrict servers in any way, you will connect to whatever server the game wants you to. You can see servers/peers on the map and ping them. Filtering Mode: Restricts games based on your settings. Strict Mode enabled: Restricts both servers and peers to within your radius Strict Mode disabled: Restricts peers to within your radius but allows servers outside the radius By default Strict Mode is on to provide the most restrictive filtering.
Rithveek Posted August 25, 2024 Posted August 25, 2024 If i want to play on eu central server of Rainbow six seige, what should i do ? I had selected the area of eu central server, Individually i am able to get matches while strict mode and filtering mode are on, but as soon as my team mates joins, we never get matches ? I have allowed their ips, able to chat with them on playstation. I have also tried turning off strict mode and turning on filtering mode but nothing happens
Administrators Netduma Fraser Posted August 25, 2024 Administrators Posted August 25, 2024 That's what you should do so you're doing it correctly. In some games what you're doing can work, the game just forces a server the lobby host can connect to, in some however it doesn't work that way and sounds like what may be happening here. In this occasion I think the only thing to do would be to have them also use a DumaOS router to force the same area as you. Geo-Latency could work in this scenario but I couldn't guarantee it and that's only available on the R3 and will be on the R2 (w/a future Early Access firmware).
Bruno Posted September 1, 2024 Posted September 1, 2024 Could you show a print of where these functions are located?
Administrators Netduma Fraser Posted September 1, 2024 Administrators Posted September 1, 2024 51 minutes ago, Bruno said: Could you show a print of where these functions are located? It's not available and will not be available on the XR range as it won't be getting DumaOS 4 Bruno 1
Arturo CG Posted September 7, 2024 Posted September 7, 2024 On 9/8/2020 at 18:09, Netduma Fraser said: Modo espectador: no restringe los servidores de ninguna manera, te conectarás a cualquier servidor que el juego te indique. Puedes ver servidores/pares en el mapa y hacer ping a ellos. Modo de filtrado: restringe los juegos según tu configuración. Modo estricto habilitado: restringe tanto a los servidores como a los pares dentro de su radio Modo estricto deshabilitado: restringe a los pares dentro de su radio, pero permite servidores fuera del radio. De forma predeterminada, el modo estricto está activado para proporcionar el filtrado más restrictivo. Buen día. Podrías agregar una imagen ilustrativa relacionado al diferente modo que se menciona. Gracias
Administrators Netduma Fraser Posted September 7, 2024 Administrators Posted September 7, 2024 5 hours ago, Arturo CG said: Buen día. Podrías agregar una imagen ilustrativa relacionado al diferente modo que se menciona. Gracias Sorry I'm not sure what you mean, could you clarify please?
