albert dh Posted July 8, 2020 Posted July 8, 2020 Hello, I have speed and connection problems with my xr300. I have changed my fiber company (now Movistar) and I have contracted fiber with a speed of 300Mb upload / 300Mb download. When I connect the XR300 router to the huawei hg8240h ont my maximum speed is always 140Mb / 120-140 Mb. If I reconnect the router of my fiber provider Comtrend VG-8050 to the ont huawei hg8240h my speed is correct and I have 300Mb / 300Mb. I think I have the XR300 router well connected to the ont using VLAN ID6 priority 1 and pppoe user / pass connection (I have been using the XR300 router for a long time). I have tried everything, disable SIP ALG, disable QOS, disable IPV6, remove Dumaos Classified games, ... Any help please? Thank you Regards
Administrators Netduma Fraser Posted July 8, 2020 Administrators Posted July 8, 2020 This is most likely due to VLAN or PPPoE as we're investigating similar issues like this on other routers. That's why I think it works when you're using the router in between the ONT and XR. I would recommend keeping that setup until 3.0 is available and that issue should be fixed.
