ONEPLUSONE-1 Posted April 17, 2020 Author Posted April 17, 2020 WARNING: No server certificate verification method has been enabled. Where is the sever certificate located? How is the verification method enabled? Is all the server information controlled and stored on the router?
ONEPLUSONE-1 Posted April 17, 2020 Author Posted April 17, 2020 I am now able to connect to both of my Hostname profiles using my iPhone, via the OpenVPN app. Not sure why but progress is progress even when I am not sure how it happens. 😉
ONEPLUSONE-1 Posted April 17, 2020 Author Posted April 17, 2020 Changing the Advanced Configuration, under VPN Service, from UDP to TCP enables me to connect on Windows OS but not Mac OS. I still get the same Warning plus another, but it does connect. I am very curious to know what the difference is between our settings that enables you to connect without my problems.
ONEPLUSONE-1 Posted April 20, 2020 Author Posted April 20, 2020 I sent the file to my friend and he gets the same errors that I get but we both show Status Connected via the OpenVPN GUI application. How does this allow the PS3’s to connect because we are not getting any different results when we try to accept game invites on the PS3’s. How does the computer control how the PS3 connects to the internet when the PS3 is directly connected to the router via ethernet cable? I guess I’m not understanding how this is actually supposed to work, if it will work at all.
Administrators Netduma Fraser Posted April 21, 2020 Administrators Posted April 21, 2020 I'm out of ideas to be honest, we didn't make the VPN service feature so perhaps it may be beneficial to make a ticket with Netgear and see if they can help with that part: http://support.netgear.com/ I've not done it myself, it was just a theory you could try. By connecting to one router then it would appear as if both are on the same network, thus allowing you to play together. I'd suggest trying to go the Hamachi route instead as that'll probably work instead.
ONEPLUSONE-1 Posted April 21, 2020 Author Posted April 21, 2020 I’ll keep searching. Thank you for all the help and ideas. I’ll let you know if I can find a solution.
