Problems party when in DMZ
Hi guys,
i just put my netduma into DMZ on my local provider acces control. Modern warfare says i have an open nat and ps4 says type 2.
But, i can’t connect with friends in party anymore i don’t hear them and they don’t hear me.
On 3/1/2020 at 11:05 AM, Cocoon992 said:
Hi guys,
If you're using the Geo-Filter then you are likely blocking them with your radius settings, add them to your allow list and then you should be able to hear them fine.
