WIFI not connecting after factory reset
Cajun72
Hi. After doing a factory reset my wifi devices will not connect. I double checked the password but still they don'e connect.
I did the factory reset because my download speeds where extremely low, which has now hopefully been resolved.
This is how is the settings for wifi since reset. But cannot get either my android phone or ipad to connect. It does find the Netduma R1 on the wifi list, but simply won't connect.
I'm on latest version of R1 2.1.3.29
I've owned the R1 since 2014 an early adopter edition.
Please help !
The WiFi password will have changed after a reset, did you change this back to what it was on the interface or re-enter it on the devices? If you forget the connection on the devices and then try to reconnect - it should ask you for the password again, does it work?
No I didn't change it back I forgot it changed after reset!
Anyway happy days as I've reconnected the wifi devices so everything ok now.
Thanks! :)
