JayKay Posted October 6, 2019 Posted October 6, 2019 Hi, Im stuck with this dutch dediserver. I tried to block and geofilter or allow/deny won't do any good. No matter what distance or area I choose. Server is listed as denied but still thats what I get. //Jay
Administrators Netduma Fraser Posted October 6, 2019 Administrators Posted October 6, 2019 When you get it does the name you blocked it with appear in the Ping window? This is showing that it's being ping assisted some how. Hard turn off the console, remove device from the Geo-Filter, flush the cloud - wait until a minute after you get the too long message and then refresh the page. Re-add the device and turn back on the console/game, do you still get the issue?
JayKay Posted January 10, 2020 Author Posted January 10, 2020 Sorry, never got back. Did that an no probs since. 👍 //Jay
JayKay Posted March 15, 2020 Author Posted March 15, 2020 Hi, Ok, problem came back and these instructions won't work. What' next? Thanks.
Administrators Netduma Fraser Posted March 15, 2020 Administrators Posted March 15, 2020 Are you changing the ping assist settings when you're already on the game at all?
JayKay Posted March 15, 2020 Author Posted March 15, 2020 No, I've tried checkin auto on an off but still the same. Not while in a game. Assist is always 0.
Administrators Netduma Fraser Posted March 15, 2020 Administrators Posted March 15, 2020 What browser are you using as well as the device you're changing the settings on? Are you on the .29 DumaOS version? Could you provide a full page screenshot of the Geo-Filter page when it is happening as well please?
JayKay Posted March 16, 2020 Author Posted March 16, 2020 Safari 13.0.5, Macbook Pro, Firmaware R1 2.1.3.29
Administrators Netduma Fraser Posted March 17, 2020 Administrators Posted March 17, 2020 Could you try using Chrome to toggle the settings when the console is off and then refresh the page, confirm it is still off and then boot up the console and see if it still happens when looking on Chrome please?
JayKay Posted March 20, 2020 Author Posted March 20, 2020 I can't log in with Chrome for some reason. Password is ok and all but still I can't get in.
Administrators Netduma Fraser Posted March 21, 2020 Administrators Posted March 21, 2020 What happens when you try to access with Chrome - does it just keep asking you for a login? Use an Incognito window, does it allow you then?
JayKay Posted March 21, 2020 Author Posted March 21, 2020 Yep, just keeps asking for a login. There is this text saying that " your connection to the site is not private". Password is ok and checked. Incognito made no difference.
Administrators Netduma Fraser Posted March 22, 2020 Administrators Posted March 22, 2020 That's very odd but it still works on Safari? If you login on safari, change the password then go back to Chrome and try with the new password does it work?
