Funkybadger Posted September 13, 2019 Posted September 13, 2019 Hello when I play any game I set my geo filter around Uk France etc etc and put ping Assist to 40ms (base ping is 15ms) and strict mode on I can find 0 matchs it will sit and search for match’s but when I make the geo filter say a 9000 miles ( nearly full map) I can find numerous games in secs I would just wondering if there’s something am doing wrong
Administrators Netduma Fraser Posted September 14, 2019 Administrators Posted September 14, 2019 What radius do you have set when you're unable to find a game? What game are you trying to play?
Funkybadger Posted September 14, 2019 Author Posted September 14, 2019 6 hours ago, Netduma Fraser said: What radius do you have set when you're unable to find a game? What game are you trying to play? Hello I play black ops 4 and ww2 I set my radius to 1000miles can’t find anything but when I set it to cover the full map I find games that are less than 500miles like uk France etc I like in Ireland
Administrators Netduma Fraser Posted September 14, 2019 Administrators Posted September 14, 2019 That's very strange, is the console added using the console server / correctly identified in Device Manager as a console?
Funkybadger Posted September 14, 2019 Author Posted September 14, 2019 10 minutes ago, Netduma Fraser said: That's very strange, is the console added using the console server / correctly identified in Device Manager as a console? Yes that’s my exact thought... am on pc I’ve added it as a console and tried adding it as a computer both make no difference yes when I go to device manger it says Aaron pc then console
Administrators Netduma Fraser Posted September 14, 2019 Administrators Posted September 14, 2019 Disable the Geo-Filter until you've booted up the game and then enable it, does it work properly then?
