Hybrid VPN. What happens when connection is lost?
When I set a device, or set specified services on a device to be behind Hybrid VPN, what happens to said device/services if connection to the VPN is lost?
Is there a kill switch in place?  Will the internet traffic be cut off to the device/services?  Or will it continue on without the VPN connection?
Well there's a toggle on Hybrid VPN called "Block Traffic If VPN Disconnects"
If this toggle is enabled, devices will NOT default back to a non-VPN connection should the VPN disconnect
