Infoseye Posted April 23, 2019 Posted April 23, 2019 My broadband provider (BT) is Download Speed 61.84mbps and upload 13.51mbps but when connected to my Netduma R1 then ran the speed test I get 37.04mbps download and upload 9.25 thats like half the speed. How do I configure the Netduma to get the full speed? Thanks
pollutionblues Posted April 23, 2019 Posted April 23, 2019 I expect you have congestion control enabled. If you disable congestion control do you get your full speeds then?
pollutionblues Posted April 23, 2019 Posted April 23, 2019 So you have congestion control enabled? If you want to receive your full speeds you need to disable congestion control by setting the sliders to 100%, remember to enable it again while gaming to stop local congestion from making you lag. Theres more info on congestion control here: http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide#Speed I would also recommend upgrading to DumaOS. Sign up here: https://netduma.com/r1-dumaos/
Infoseye Posted April 23, 2019 Author Posted April 23, 2019 Thanks for the help, using the old firmware works much better for me. I had issues with DumaOS, such as I shoot first and die first, randomly get destroyed on cod bo4 I be like what just happened moment that are unexplainable. Reverting back to the old firmware works for me. My hit detection/ hit marker is always on point. I will certainly upgrade in future but I'm good.
pollutionblues Posted April 23, 2019 Posted April 23, 2019 3 minutes ago, Seye said: Thanks for the help, using the old firmware works much better for me. I had issues with DumaOS, such as I shoot first and die first, randomly get destroyed on cod bo4 I be like what just happened moment that are unexplainable. Reverting back to the old firmware works for me. My hit detection/ hit marker is always on point. I will certainly upgrade in future but I'm good. Great! I’ll lock this thread now. If you need more help create a new thread.
Administrators Netduma Admin Posted April 23, 2019 Administrators Posted April 23, 2019 Thanks for all the help PB
