Tymsy Posted November 18, 2018 Posted November 18, 2018 Hi, I have a ring door bell and it seems using the Netduma R1 drains the battery way quicker than when using the normal virgin media hub, is there a setting I can change to stop this happening?
Administrators Netduma Fraser Posted November 18, 2018 Administrators Posted November 18, 2018 Uhm, I'm not sure there is a correlation here. Theres no settings for stop batteries draining quicker, I wouldn't even know the first place to consider looking to be honest. Maybe just limit it's bandwidth to just what it needs under Bandwidth Allocation and disable share excess.
Tymsy Posted November 18, 2018 Author Posted November 18, 2018 I had to stop using the Netduma router when i kept having to replace its battery, went from 1 weeks use to lasting 3 months on the virgin router. Just updated to duma OS and still seems to drain fast 😞
Administrators Netduma Fraser Posted November 18, 2018 Administrators Posted November 18, 2018 I don't really understand why that would be a thing tbh. Check the network monitor to see how much data it's using if it's using a lot then try what I said above
