Hybrid VPN issue on DumaOS for R1
Hi,
I'm beta user and i tested the last feature of DumasOS on R1 router.
I have a privateVPN account and and I get this issue with the OpenVPN configuration file:
Wed Nov 14 21:04:56 2018 OpenVPN 2.3.4 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 4 2018
Wed Nov 14 21:04:56 2018 library versions: OpenSSL 1.0.1h 5 Jun 2014, LZO 2.06
Wed Nov 14 21:04:56 2018 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Nov 14 21:04:56 2018 Cipher algorithm 'AES-128-GCM' not found (OpenSSL)
Wed Nov 14 21:04:56 2018 Exiting due to fatal error
I cheched on google and it seem that cipher aes-128-gcm is supported since OpenVPN 2.4 and DumaOS is OpenVPN 2.3:
https://github.com/Tunnelblick/Tunnelblick/issues/378
You will find in attached the official OpenVPN file configuration.
Can you please update your release to OpenVPN 2.4 at least !?
Thanks
PrivatVPN-US-Buffalo-TUN-1194.ovpn
If that needs to be done, then we'll let the developers know. Have you tried with the TAP ovpn files? If so do you get the same, if not can you try that please.
Okay so either its the reason you said or it could be:
  • Inputting incorrect username/password
  • Server is down
So could you try with an alternative server, does that work?
If you use the PC VPN client can you connect with the login details/same server?
Hi Fraser,
I tested with another location (Zurich) that I also use on my Nvidia shield with openvpn too.
Results are same with both, tun and tap.
As you requested, I tested again on my nvidia shield and it success,
It is not a credentials issue because I success to connect on my account on private vpn site (it is same credential for openvpn).
In addition, the logs that I sent you are complete and it stop from the begining before any authentication.
Okay thanks for the additional info. Based on what you've said I've gone ahead and let a developer know so they can look into it.
