problem after installing milestone 1.3
umpmanjoe
I have netduma R1 router.  On the old firmware, I found great lobbies in BO4. I always connected to a server within 400 miles of me and generally had a 20 ping to server.  Installed milestone and set ping assist to 50 with a radius of 1000 miles and I cant get into a game.  I waited for over 10 minutes and nothing shows up.  I finally got into a game and the ping was over 100 with lots of spikes.  I tried everything I read including rebooting the game and rebooting the router.  I really want to take advantage of dumaOS but every time I install it, I cant find lobbies.  Is there something I'm missing?
I am running the netduma behind an Asus AC88U.  The only device hooking up to the Netduma router is my PS4 and my Xbox One.   I also login to the netduma screen through the wan on my iMac, which is connected to the main network.
Are you referring to 6j or previous DumaOS firmware?
Do you have fast search enabled/disabled? Is the ping you're referring to on the Geo-Filter or the in game reading?
If you're using fast search  I would recommend you disable that. Also where abouts are you located?
when I say "on the old firmware", I'm referring to 6j.  I had no luck finding lobbies when I upgraded to dumaOS either.  I figured I would try again with this new version but am having the same problem.     I have tried with faster enable and with it disabled.    The ping I'm referring to is on the geo-filter.   I'm in south Florida.  Like I said, when I run 6j, I get great lobbies with very low ping.
I think this is probably related to the update last night.
It has been suggested by others to leave the Geo-Filter on Spectating Mode with your Geo-Filter settings done. Then boot up the game. When you're in the lobby then enable Filtering Mode. Wait 2 minutes then search for a game, hopefully from there you can leave it as is and continually get games within your settings ranges.
Also quoting Netduma Admin on this:
We have tested this a lot today - continually restarting the game and playing multiplayer a lot. So far, we have not seen any change in behaviour. Our thinking is Treyarch's patch temporarily caused server issues last night so a lot of people were not able to connect to games (whether they owned our router or not). This graph for the last 24 hours suggests the same: https://downdetector.com/status/call-of-duty/news/230092-problems-at-call-of-duty
Could you all please reboot your routers, set Ping Assist to 30ms and also restart your consoles / gaming PC. Should hopefully be similar to your pre-patch experience after this.
If it is not, please restart the game again and try once more. If it continues, could you then post a screenshot of your Geo-Filter settings as this will help us to help you.
