Merciless jayy Posted October 28, 2018 Posted October 28, 2018 This is my first time powering up my netduma in almost a year and now im having problem logging on to the interface, i tried 192.168.88.1 and http://r1 neither works i really wanna use my netduma are yhere any solutions please help
pollutionblues Posted October 28, 2018 Posted October 28, 2018 2 hours ago, Merciless jayy said: This is my first time powering up my netduma in almost a year and now im having problem logging on to the interface, i tried 192.168.88.1 and http://r1 neither works i really wanna use my netduma are yhere any solutions please help Hi, Welcome to the forum. I have moved this to to correct section, please do not post in the 1 on 1 section unless instructed to do so by Netduma staff. connect your PC to the R1 (wired or wireless) 1. Open your Windows Start Menu 2. Type in cmd and press enter 3. In the black window that opens, type in ipconfig and press enter  4. Take a screenshot of the results and post here.
pollutionblues Posted October 28, 2018 Posted October 28, 2018 54 minutes ago, Merciless jayy said: Either you’ve changed the LAN IP of the R1 or you aren’t actually connected to it. What do you get if you type in the default gateway IP address?
Merciless jayy Posted October 28, 2018 Author Posted October 28, 2018 Im connected to the r1 so that mean i probably change the lan ip which i dont know how i could of. Is it anyway to reset it
pollutionblues Posted October 29, 2018 Posted October 29, 2018 Connect the R1 to your PC via Ethernet cable and turn off WiFi on your PC. Can you connect to the R1 interface now?
Merciless jayy Posted October 29, 2018 Author Posted October 29, 2018 I tried that its still the same thing. It just tel me the site can be reached
pollutionblues Posted October 29, 2018 Posted October 29, 2018 What browser are you using? Can you clear your browsers cache & cookies and try again.
pollutionblues Posted October 29, 2018 Posted October 29, 2018 3 minutes ago, Merciless jayy said: Im using mircosoft edge That may be your problem. Google Chrome is the recommended browser. Can you access the UI if you use Chrome?
Merciless jayy Posted October 29, 2018 Author Posted October 29, 2018 Omg i clear the cache and went to chrome and tada!!! It worked. Also do i need any upgrades for my netduma
Merciless jayy Posted October 29, 2018 Author Posted October 29, 2018 I pulled up the interface but if goes out. Npw its saying i have no internet in the netduma. But its connected
pollutionblues Posted October 29, 2018 Posted October 29, 2018 Is your modem connected to port 1 of the R1?
Merciless jayy Posted October 29, 2018 Author Posted October 29, 2018 I have on connected in poE and one in port 3, but the thing is my wifi light is not on
Administrators Netduma Fraser Posted October 29, 2018 Administrators Posted October 29, 2018 The WiFi light won't appear on the R1. Do you have internet if you connect via ethernet? Is it just through WiFi?
Merciless jayy Posted October 29, 2018 Author Posted October 29, 2018 I had to power cycle the r1 it was saying im using port 4 in whixh case i wasnt, now im on the netduma interface
Administrators Netduma Fraser Posted October 30, 2018 Administrators Posted October 30, 2018 That's very weird. Did you have anything plugged into port 4 previously?
Merciless jayy Posted October 30, 2018 Author Posted October 30, 2018 No there wasnt. That was very weird
Administrators Netduma Fraser Posted October 31, 2018 Administrators Posted October 31, 2018 Is it still ocurring? I can not think of any reason that would have happened unless the light tube broke allowing the light from another port in
Merciless jayy Posted November 1, 2018 Author Posted November 1, 2018 Im good to go i have access to my interface and im using my ri for bo4 as we speak. Thanks alot for your help fraser
pollutionblues Posted November 1, 2018 Posted November 1, 2018 5 hours ago, Merciless jayy said: Im good to go i have access to my interface and im using my ri for bo4 as we speak. Thanks alot for your help fraser Great! As your sorted now I’ll lock this thread.
