Netduma Staff Netduma Crossy Posted December 30, 2014 Netduma Staff Posted December 30, 2014 I was wondering if it was possible to have items that are not connected to my network anymore remove them selves. I have seen that friends phones stay on the network monitor and connection control and device manager even when they are not connected to the network. Is there a setting anywhere which I can make it so it does not shows them or do I have to go into network manager and remove them? Thanks
Guest Netduma_Iain Posted December 30, 2014 Posted December 30, 2014 Hi Crossy, Yes if you go to "Device Manager", click edit at the top. It lists a table of all devices you can delete them there(as well as block if you want )
Netduma Staff Netduma Crossy Posted December 30, 2014 Author Netduma Staff Posted December 30, 2014 Hi Crossy, Yes if you go to "Device Manager", click edit at the top. It lists a table of all devices you can delete them there(as well as block if you want ) Ok, I see, but is there no way for the non active devices to be removed automatically? Thanks
Guest Netduma Fraser Posted December 30, 2014 Posted December 30, 2014 Ok, I see, but is there no way for the non active devices to be removed automatically? Thanks We could have it on a timeout, say been inactive for a day and then it gets removed? Let me know how youd like it to work.
abc123 Posted December 30, 2014 Posted December 30, 2014 We could have it on a timeout, say been inactive for a day and then it gets removed? Let me know how youd like it to work. 100% agree, i'd argue 2x DHCP lease time.
Netduma Staff Netduma Crossy Posted December 30, 2014 Author Netduma Staff Posted December 30, 2014 sounds a good idea Yeah, I like that idea
rameses Posted December 31, 2014 Posted December 31, 2014 I was trying to delete some devices from the Device Manager tab, but I get "The device can not be delete because it is still active. Please disconnect the device, reset the router then delete the device." Is this correct? I have my devices connected to my nighthawk which is connected to the Netduma.
abc123 Posted December 31, 2014 Posted December 31, 2014 I was trying to delete some devices from the Device Manager tab, but I get "The device can not be delete because it is still active. Please disconnect the device, reset the router then delete the device." Is this correct? I have my devices connected to my nighthawk which is connected to the Netduma. this means the device still has it's DHCP Lease, if you go to Settings > DHCP (Lease Time) that's how long you have to wait before you could delete the device. basically overtime it will say dormant
Guest Netduma_Iain Posted December 31, 2014 Posted December 31, 2014 Abc is correct rameses. However if you want to delete it really quick. Just restart the router(pull plug out, wait 10s, put plug back in) then go find the device and you'll be able to delete it now.
