Needing help setting up netduma
I am needing help getting my netduma to show players i am connecting with through the geo filter i have ps network chose and is set to enabled also i am running ver1.03.6i
Flush the cloud then hard turn off your console, delete device from Geo-Filter, re-add device to Geo-Filter, boot up your console and the game.
To flush the cloud, goto miscellaneous > Cloud Settings make sure auto cloud and bleeding edge are ticked and click ‘Apply Cloud Settings’ this will flush the cloud.
Please don’t post in th 1 on 1 section unless instructed to do so by a member of Netduma staff. I have moved this topic to the correct location. Thanks
Hi Murzi, welcome to the forum! Looks like you've been given some great advice above. Bear in mind that Black Ops 4 is still in its early days so they have a lot to sort out on their end as well. Please let us know if the solution above works for you :)
