DAKOTADOCKALL Posted August 5, 2018 Posted August 5, 2018 I feel like iv been getting DDOSed the past hour. is there anyway i can see that on the R1 or is there any software i can use on my pc to find out?
DAKOTADOCKALL Posted August 5, 2018 Author Posted August 5, 2018 False alarm i called my ip and they said it was there fault and i also looked and saw that the r1 doesnt not give logs to prevent bad behavior with it
iAmMoDBoX Posted August 5, 2018 Posted August 5, 2018 I feel like iv been getting DDOSed the past hour. is there anyway i can see that on the R1 or is there any software i can use on my pc to find out? If you are getting ddosed you can change your IP if you are on US cable usually by changing the mac address of the router and then rebooting the modem
DAKOTADOCKALL Posted August 5, 2018 Author Posted August 5, 2018 oh wow that easy thanks for the info greatly appreciative
